Datasheet Texas Instruments UCC35701Q — Даташит
| Серия | UCC35701 |
| Модель | UCC35701Q |
Advanced Voltage Mode Pulse Width Modulator datasheet
PDF, 984 Кб, Версия: C, Файл опубликован: 17 июн 2005
1.2A SWITCHING CONTROLLER, 700kHz SWITCHING FREQ-MAX, QCC20, LCC-20 | |||
| UCC35701Q Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 20 |
| Package Type | UTR |
| Approx. Price (US$) | 2.95 | 1ku |
| Control Method | Feedforward Voltage |
| Duty Cycle(Max)(%) | 99 |
| Frequency(Max)(kHz) | 700 |
| Gate Drive(Typ)(A) | 1 |
| Operating Temperature Range(C) | 0 to 70 |
| Package Group | SOIC PDIP TSSOP |
| Rating | Catalog |
| Special Features | Multi-topology Soft Start Synchronization Pin |
| Topology | Boost Buck Flyback Forward |
| UVLO Thresholds On/Off(V) | 13/9 |
| Vin(Max)(V) | 15 |
| Vin(Min)(V) | 9 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- U-150 Applying the UCC3570 Voltage-Mode PWM Controller to Both Off-LinePDF, 568 Кб, Файл опубликован: 5 сен 1999
The UCC3570 families of pulse-width modulators are for application in isolated switching supplies using primary-side control and a voltage-mode feedback loop. BiCMOS processing provides higher switching frequencies at lower quiescent current drain, while including innovations in both performance and protection features. Its versatility is demonstrated with the description of a 50W, wide input-volt - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UCC35701 (8)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
