Datasheet Texas Instruments TPS720115DRVT — Даташит
СерияTPS720
МодельTPS720115DRVT
350 мА, сверхнизкий VIN, ВЧ линейный стабилизатор с малым падением напряжения и контактом смещения 6-WSON от -40 до 125
TPS720 350 mA, Ultra-Low VIN, RF Low-Dropout Linear Regulator With Bias Pin datasheet
PDF, 2.0 Мб, Версия: E, Файл опубликован: 30 сен 2015
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Width (мм)2
Length (мм)2
Thickness (мм)0.75
Pitch (мм)0.65
Max Height (мм)0.8
Точность2 %
Основные особенностиEnable,Soft Start
Fixed Output Options0.9,1,1.05,1.1,1.15,1.2,1.3,1.5,1.7,1.8 В
Iout(Max)0.35 A
Iq(Typ)0.038 мА
Noise48 uVrms
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz55 дБ
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Regulated Outputs1
Thermal Resistance ОёJA67 В°C/W
Vdo(Typ)110 мВ
Vin(Max)4.5 В
Vin(Min)1.1 В
Vout(Max)1.8 В
Vout(Min)0.9 В
  • Evaluation Modules & Boards: K2GICE
    66AK2Gx (K2G) Industrial Communications Engine (ICE)
  • Evaluation Modules & Boards: TPS720105DRVEVM
    Evaluation Module for TPS720105 Low-Dropout Linear Regulator in DRV (SON-6) Package
  • Evaluation Modules & Boards: TPS72015EVM-307
    TPS72015EVM-307 Evaluation Module
  • Inrush Current Limit in the TPS720xx
    PDF, 108 Кб, Файл опубликован: 6 июн 2008
    When not properly limited the inrush current in low-dropout regulators (LDOs) can cause system level failures. The TPS720xx series of LDOs have a unique inrush current limit feature and a monotonic output voltage ramp which significantly eases the system level power-supply design. This application report explains how the TPS720xx inrush current limit is different from other inrush limit schemes
  • Power Reference Design for the 'C6472 12V DCDC Controllers and LDOs
    PDF, 245 Кб, Файл опубликован: 26 мар 2010
    This reference design is intended for designers who wish to design a TMS320C6472 Digital Signal Processor into a system using a nominal input voltage of 12 V external FETs for design flexibility and low-dropout regulators for the low-power rails.
  • Taming linear-regulator inrush currents
    PDF, 706 Кб, Файл опубликован: 1 май 2009
  • Q2 2009 Issue Analog Applications Journal
    PDF, 1.7 Мб, Файл опубликован: 1 май 2009
На английском языке: Datasheet Texas Instruments TPS720115DRVT
