Datasheet Texas Instruments THS5641AIPWR — Даташит
СерияTHS5641A
МодельTHS5641AIPWR
8-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 100 MSPS 28-TSSOP от -40 до 85
8-Bit, 100 MSPS, CommsDAC(TM) Digital-to-Analog Converter datasheet
PDF, 915 Кб, Версия: A, Файл опубликован: 25 сен 2002
IC DAC 8BIT A-OUT 28TSSOP. 8 Bit Digital to Analog Converter 1 28-TSSOP. Data Acquisition - Digital to Analog Converters (DAC)...
THS5641AIPWR
232 ₽
THS5641AIPWR
370 ₽
Эиком
THS5641AIPWR
от 1 150 ₽
Hi-Tech Circuit Group
THS5641AIPWR
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTJ5641A
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Power Consumption(Typ)100 mW
Разрешение8 Bits
SFDR55 дБ
Sample / Update Rate100 MSPS
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5641AIPWR
