Datasheet Texas Instruments LM34925MR/NOPB — Даташит
СерияLM34925
МодельLM34925MR/NOPB
Встроенный стабилизатор вторичного смещения, напряжение 7,5–100 В, напряжение 100 мА для изолированных преобразователей постоянного тока в постоянный ток 8-SO PowerPAD
LM34925 Integrated Secondary-Side Bias Regulator for Isolated DC-DC Converters datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 11 ноя 2014
IC REG BUCK ADJ 100MA DL 8SOPWR. Buck Switching Regulator IC Positive, Isolation Capable Adjustable 1.225V 1 Output 100mA 8-PowerSOIC (0.154',...
Рутоника
LM34925MR/NOPB
145 ₽
LM34925MR/NOPB
186 ₽
LM34925MR/NOPB
227 ₽
727GS
LM34925MR/NOPB
Package TypeDDA
Industry STD TermHSOIC
Package QTY95
МаркировкаS000YB
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
Iout0.1 A
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Soft StartNone
Special FeaturesAdjustable UVLO,Enable
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)150 kHz
TopologyBuck,Flybuck
ТипConverter (Integrated Switch)
Vin(Max)100 В
Vin(Min)9 В
Vout(Max)90 В
Vout(Min)1.25 В
  • Evaluation Modules & Boards: LM34925EVAL
    LM34925 Isolated Bias Supply Evaluation Module
  • LM34925 Isolated Evaluation Board (Rev. A)
    PDF, 516 Кб, Версия: A, Файл опубликован: 23 апр 2013
    An isolated bias supply is implemented in this evaluation board with LM34925 Constant-On-Timeregulator. The LM34925 regulator integrates both the high and low side power switches essential forcreating isolated buck converter.The following include the board specifications:Input Range: 20V to 100VPrimary Output Voltage: 10VSecondary (Isolated) Output Voltage:
  • Fly-Buck(TM) converter provides EMC and isolation in PLC applications
    PDF, 201 Кб, Файл опубликован: 29 янв 2015
  • AN-2292 Designing an Isolated Buck (Fly-Buck) Converter (Rev. C)
    PDF, 870 Кб, Версия: C, Файл опубликован: 17 дек 2014
    In many applications, one or more low-cost, simple to use, isolated power supplies working from input voltages up to 100 V are needed. Traditional solutions use flyback converters to generate this bias supply. Flyback designs typically utilize asymmetric transformers turns ratios for primary and secondary power windings, with an optocoupler and reference, or an auxiliary winding for feedback regul
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Isolated DC/DC Converter
На английском языке: Datasheet Texas Instruments LM34925MR/NOPB
