Datasheet Texas Instruments SN65LBC182P — Даташит
СерияSN65LBC182
МодельSN65LBC182P
Полудуплекс, ESD 15 кВ, приемопередатчик 1/4 UL 8-PDIP от -40 до 85
SN65LBC182, SN75LBC182 Differential Bus Transceiver datasheet
PDF, 877 Кб, Версия: A, Файл опубликован: 25 мар 2005
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Маркировка65LBC182
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Common Mode Range-7 to 12
DuplexHalf
Fail SafeOpen
Fault Protection-10 to 15 В
HBM ESD15 kV
ICC(Max)30 мА
IEC 61000-4-2 Contact8 +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes128
Package GroupPDIP
Signaling Rate(Max)0.25 Mbps
Supply Voltage(s)(Nom)5 В
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • RS-485 for E-Meter Applications (Rev. A)
    PDF, 311 Кб, Версия: A, Файл опубликован: 6 авг 2004
    This application report discusses the best practices for designing energy meter communication circuits using the RS-485 standard. Component selection and performance tradeoffs are covered with reference to relevant standards such as IEC 61036 and DL/T 645. Reference design details are provided to help energy meter engineers successfully complete their own circuit designs.
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65LBC182P
