Datasheet Texas Instruments LM3414HVMRX/NOPB — Даташит
СерияLM3414HV
МодельLM3414HVMRX/NOPB
Драйвер светодиода постоянного тока с общим анодом мощностью 60 Вт не требует дополнительных устройств.
LM3414/HV 1-A, 60-W Common Anode-Capable Constant Current Buck LED Driver Requires No External Current Sensing Resistor datasheet
PDF, 1.7 Мб, Версия: F, Файл опубликован: 3 дек 2015
Разрешение измерения тока 8-SO PowerPAD от -40 до 125
Pin88
Package TypeDDADDA
Industry STD TermHSOICHSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаHVMRL3414
Width (мм)3.93.9
Length (мм)4.894.89
Thickness (мм)1.481.48
Pitch (мм)1.271.27
Max Height (мм)1.71.7
Dimming MethodAnalog,PWM
Входное напряжениеDC/DC Type
Iout(Max)1 A
Iq(Typ)3.3 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)250 kHz
TopologyBuck
ТипConverter,Inductive
Vin(Max)65 В
Vin(Min)4.5 В
Vout(Max)65 В
Vout(Min)0.2 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3414HVSDEVAL
    LM3414 LM3414HV 1A 65V LED Driver LLP-8 Evaluation Board
  • Evaluation Modules & Boards: LM3414HVMREVAL
    LM3414 LM3414HV 1A 65V LED Driver PSOP-8 Evaluation Board
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3414HVMRX/NOPB
