Datasheet Texas Instruments TMS320F28377DPTPT — Даташит
СерияTMS320F28377D
МодельTMS320F28377DPTPT
Двухъядерный микроконтроллер Delfino 176-HLQFP от -40 до 105
TMS320F2837xD Dual-Core Delfinoв„ў Microcontrollers datasheet
PDF, 2.8 Мб, Версия: H, Файл опубликован: 25 июл 2017
Pin176176
Package TypePTPPTP
Industry STD TermHLQFPHLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY4040
МаркировкаTMS320F28377DPTPT
Width (мм)2424
Length (мм)2424
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC9,12,20,24 Ch
ADC Resolution16-bit /12-bit
CAN2
CPU2x C28x,2x CLA
DAC3
DMA12 Ch
EMIF1 32/16-Bit,1 16-Bit
FPUYes
Flash1024 KB
Тактовая частота200 МГц
High Resolution PWM16 Ch
I2C2
McBSP2
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM24 Ch
Pin/Package176HLQFP, 337NFBGA
QEP2
RAM204 KB
SPI3
Security EnablerDebug security,Software IP protection
Sigma-Delta Filter8
Total Processing800 MIPS
UART4 SCI
USB1
  • Development Kits: TMDSECATCNCD379D
    EtherCAT Slave and C2000 Delfino MCU controlCARD Kit for Industrial Factory Automation Applications
  • Development Kits: TMDXIDDK379D
    C2000 DesignDRIVE Development Kit for Industrial Motor Control
  • Evaluation Modules & Boards: LAUNCHXL-F28377S
    C2000 Delfino MCUs F28377S LaunchPad Development Kit
  • Development Kits: TIEVM-HV-1PH-DCAC
    Single Phase Inverter Reference Design With Voltage Source and Grid Connected Modes
  • Development Kits: TMDSCNCD28379D
    F28379D controlCARD for C2000 Real time control development kits
  • Development Kits: TMDSDOCK28379D
    F28379D Delfino Experimenter Kit
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Flexible PWMs Enable Multi-Axis Drives, Multi-Level Inverters
    PDF, 39 Кб, Файл опубликован: 11 май 2016
    High-performance control peripherals are an integral component for all digital control systems. The hallmark of the Delfino F2837xD devices are the control peripherals including the flexible, powerful, industry-proven PWM timers. Each of the PWM modules is enhanced to support high resolution capabilities on both A and B channels. These high-resolution channels extend 150ps PWM step resolution to e
  • High-Performance, High-Precision, Smart Sensing for Industrial Drives
    PDF, 41 Кб, Файл опубликован: 11 май 2016
    In higher end control applications such as servo drives, high-resolution feedback is required to provideprecise phase current measurements for low-torque ripple and precision positioning; however, for somemeasurements, precise sample rates are more important than higher resolution, such as when makinghigh-speed, low-side shunt current measurements. To support different accuracy requirements,
  • Built-In System Protection for Industrial Drives
    PDF, 58 Кб, Файл опубликован: 11 май 2016
    Eight windowed comparators are integrated into the Delfino F2837xD MCU architecture, providing “trip points,” and operate independently from the CPU so there is no additional CPU loading. The comparators are also fast acting (50 ns reaction to trip!) and CPU independent to minimize latency with trip signals so the system can react quickly to any abnormal events or over/under limit conditions. The
  • High Bandwidth Current Control of 3-Phase PMSM Using F2837x FCL Library
    PDF, 1.5 Мб, Файл опубликован: 8 май 2017
  • Fast Current Loop Library
    PDF, 42 Кб, Файл опубликован: 8 май 2017
  • The TMS320F2837xD Architecture: Achieving a New Level of High Performance
    PDF, 384 Кб, Файл опубликован: 11 фев 2016
    With the utilization of advanced high-performance microcontroller architectures, sophisticated real-time control systems can be realized. By combining both analog and digital control peripherals into a single device, along with a dual-core design, these systems can be cost-effectively implemented. This document provides an introduction and general overview to the TMS320F2837xD device architectural
  • Accessing External SDRAM on the TMS320F2837x/280 Microcontrollers Using C/C++
    PDF, 62 Кб, Файл опубликован: 30 мар 2015
    The TMS320F2837x and TMS320F2807x microcontrollers provide facilities for interfacing to external SDRAM memory through two external memory interface modules. The address space for this memory lies beyond the 22-bit addressable range traditionally accessed with the C28x CPU. This application report describes how to access the SDRAM memory from C/C++ code.
  • Sensored Field Oriented Control of 3-Phase Perm Magnet Sync Motors Using F2827x
    PDF, 1.2 Мб, Файл опубликован: 12 фев 2016
    This application report presents a solution to control a permanent magnet synchronous motor (PMSM) using the TMS320F2837x microcontrollers. TMS320F2837x devices are part of the family of C2000 microcontrollers, which enables the cost-effective design of intelligent controllers for three phase motors by reducing system components and increasing efficiency. With these devices, it is possible to real
  • Interfacing the C2000 with an AFE03x: B-FSK Example
    PDF, 2.7 Мб, Файл опубликован: 30 июн 2017
    This application report provides information on how to interface a C2000 device with an AFE031, and send data over a wired coupled interface using frequency shift keying. A demonstration of transmitting FSK information is discussed with tone frequencies in the 130-145 kHz range.
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Getting Started With TMS320C28x Digital Signal Controllers (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 25 окт 2007
    This guide is organized by development flow and functional areas to make your design effort as seamless as possible. Tips on getting started with TMS320C28xв„ў DSP software and hardware development are provided to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, software, and tools for use in each phase of d
  • TMS320C28x FPU Primer (Rev. A)
    PDF, 228 Кб, Версия: A, Файл опубликован: 20 июл 2009
    This primer provides an overview of the floating-point unit (FPU) in the C2000в„ў Delfino microcontroller devices.
  • An Overview of Designing Analog Interface With TM320F28xx/28xxx DSCs (Rev. A)
    PDF, 655 Кб, Версия: A, Файл опубликован: 14 май 2008
    This application report provides guidelines that take you through everything from configuring the ADC and related registers correctly, responding to interrupts, and board design recommendations; this may be particularly useful for first-time users of the TMS320C2000в„ў digital signal processor (DSP) platform devices and for firmware engineers with less exposure to the analog world. Various s
  • Using PWM Output as a Digital-to-Analog Converter on a TMS320F280x (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 9 сен 2008
    This application report presents a method for utilizing the on-chip pulse width modulated (PWM) signal generators on the TMS320F280xв„ў family of digital signal controllers as a digital-to-analog converter (DAC). The method involves analog low-pass filtering the PWM signal to remove high frequency components, leaving only the low-frequency content. Theoretical and experimental results are presented
  • Running an Application from Internal Flash Memory on the TMS320F28xxx DSP (Rev. L)
    PDF, 641 Кб, Версия: L, Файл опубликован: 28 фев 2013
    Several special requirements exist for running an application from on-chip Flash memory on the TMS320F28xxx. These requirements generally do not manifest themselves during code development in RAM since the Code Composer Studioв„ў (CCS) debugger can mask problems associated with initialized sections and their linkage in memory. This application report covers the application software modificatio
  • Flash Programming Solutions for the TMS320F28xxx DSCs
    PDF, 423 Кб, Файл опубликован: 19 авг 2008
    Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the
  • Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)
    PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
    This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed.
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Delfino F2833x/F2837x
На английском языке: Datasheet Texas Instruments TMS320F28377DPTPT
