Datasheet Texas Instruments SN74LVC16374AGRDR — Даташит
Серия | SN74LVC16374A |
Модель | SN74LVC16374AGRDR |
16-разрядный триггер D-типа с триггером по фронту и выходами с 3 состояниями 54 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVC16374A 16-Bit Edge-Triggered D-Type Flip-Flop With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 24 июл 2014
Pin | 54 |
Package Type | GRD |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Width (мм) | 5.5 |
Length (мм) | 8 |
Thickness (мм) | .8 |
Pitch (мм) | .8 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | SN74LVC16374AZRDR |
Replacement Code | P |
3-State Output | Yes |
Approx. Price (US$) | 0.49 | 1ku |
Bits(#) | 16 |
F @ Nom Voltage(Max)(Mhz) | 100 |
ICC @ Nom Voltage(Max)(mA) | 0.02 |
Тип входа | TTL CMOS |
Operating Temperature Range(C) | -40 to 125 -40 to 85 |
Output Drive (IOL/IOH)(Max)(mA) | 24/-24 |
Тип выхода | CMOS |
Package Group | BGA MICROSTAR JUNIOR |
Package Size: mm2:W x L (PKG) | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max)(V) | 3.6 |
VCC(Min)(V) | 1.65 |
Voltage(Nom)(V) | 1.8 2.5 2.7 3.3 |
tpd @ Nom Voltage(Max)(ns) | 6.5 4.3 4.9 4.5 |
RoHS | Не совместим |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC16374A (10)
- Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
