Datasheet Texas Instruments TPS61003DGS — Даташит
СерияTPS61003
МодельTPS61003DGS
Повышающий преобразователь с низким входным напряжением и фиксированным выходным напряжением 2,5 В, 10-VSSOP от -40 до 85
Datasheet
TSP
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
МаркировкаADD
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Approx. Price (US$)1.22 | 1ku
Duty Cycle(Max)(%)100
Iq(Typ)(mA)0.05
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Regulated Outputs(#)1
Special FeaturesEnable
Light Load Efficiency
Power Good
Switch Current Limit(Min)(A)0.9
Switch Current Limit(Typ)(A)0.9
Switching Frequency(Max)(kHz)840
Switching Frequency(Min)(kHz)360
ТипConverter
Vin(Max)(V)2.5
Vin(Min)(V)0.8
Vout(Max)(V)2.5
Vout(Min)(V)2.5
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61003 (1)
  • TPS61003DGS
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61003DGS
