Datasheet Texas Instruments SN74LVCH245ARGYRG4 — Даташит
СерияSN74LVCH245A
МодельSN74LVCH245ARGYRG4
Восьмеричный шинный трансивер с выходами с 3 состояниями 20-VQFN от -40 до 85
SNx4LVCH245A Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 6 май 2014
Pin20
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаLCH245A
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Bits8
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)12.7,8.3,7.3,6.3 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCH245ARGYRG4
