Datasheet Texas Instruments UCC39412PW — Даташит
| Серия | UCC39412 |
| Модель | UCC39412PW |
Синхронный повышающий преобразователь малой мощности 8-TSSOP от 0 до 70
Low Power Synchronous Boost Converter datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 20 июл 2005
Купить UCC39412PW на РадиоЛоцман.Цены — от 112 до 866 ₽14 предложений от 14 поставщиков IC REG BOOST 3.3V 60MA 8TSSOP. Boost Switching Regulator IC Positive Fixed 3.3V 1 Output 60mA 8-TSSOP (0.173', 4.40mm Width). PMIC... | |||
| UCC39412PW Texas Instruments | 112 ₽ | ||
| UCC39412PW Texas Instruments | 340 ₽ | ||
| UCC39412PW Texas Instruments | 695 ₽ | ||
| UCC39412PW Rochester Electronics | по запросу | ||
| Pin | 8 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 150 |
| Carrier | TUBE |
| Маркировка | 39412 |
| Width (мм) | 4.4 |
| Length (мм) | 3 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Duty Cycle(Max) | 100 % |
| Iq(Typ) | 0.048 мА |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | TSSOP |
| Rating | Catalog |
| Regulated Outputs | 1 |
| Switch Current Limit(Min) | 0.385 A |
| Switch Current Limit(Typ) | 0.55 A |
| Switching Frequency(Max) | 500 kHz |
| Switching Frequency(Min) | 500 kHz |
| Тип | Converter |
| Vin(Max) | 3.8 В |
| Vin(Min) | 1 В |
| Vout(Max) | 3.3 В |
| Vout(Min) | 3.3 В |
- Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UCC39412 (2)
- UCC39412PW UCC39412PWTR
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
