Datasheet Texas Instruments LM25085SD/NOPB — Даташит
СерияLM25085
МодельLM25085SD/NOPB
Несинхронный понижающий контроллер на PFET-транзисторах с постоянным напряжением 4,5–42 В и постоянным напряжением 8-WSON от -40 до 125
LM25085 / -Q1 42V Constant On-Time PFET Buck Switching Controller datasheet
PDF, 1.7 Мб, Версия: J, Файл опубликован: 3 ноя 2014
Package TypeNGQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
CarrierSMALL T&R
МаркировкаL246B
Width (мм)3
Length (мм)3
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Control ModeConstant on-time (COT)
Duty Cycle(Max)100 %
Iout(Max)10 A
Iq(Typ)1.25 мА
Number of Phases1
Package GroupWSON
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Frequency Synchronization
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)42 В
Vout(Min)1.25 В
  • Evaluation Modules & Boards: LM25085MYEVAL
    Evaluation Board for LM25085 - 42V Wide Vin Constant On-Time PFET Buck Switching Controller
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Constant Current Constant Voltage Buck Converter w/LM25085 (Rev. A)
    PDF, 377 Кб, Версия: A, Файл опубликован: 23 апр 2013
    In many applications, a constant-current constant-voltage (CC/CV) dc source is needed. The I-Vcharacteristic of a constant-current constant-voltage (CC/CV) source is shown in Figure 1. This applicationreport presents an external op-amp based accurate current limit circuit suitable for CC/CV operation whenthe required constant current range is very narrow.
  • Transient Response versus Ripple – An Analysis of Ripple Injection Techniques
    PDF, 2.9 Мб, Файл опубликован: 28 апр 2014
    In this application note the implications of ripple injection techniques, aimed at minimizingoutput ripple voltage, on the transient response of a supply are highlighted. The results help choose a suitable ripple injection technique after striking a balance between the output ripple voltage and the transient response required by the load.
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM25085SD/NOPB
