Datasheet Texas Instruments ADS8401IBPFBTG4 — Даташит
СерияADS8401
МодельADS8401IBPFBTG4
16-разрядный параллельный АЦП, 1,25 MSPS, Ref 48-TQFP от -40 до 85
Datasheet
TSP
АЦП азиатских производителей
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Рекомендуемая замена
ReplacementADS8405IBPFBTG4
Replacement CodeS
RoHSНе совместим
  • Interfacing the ADS8401/ADS8411 to TMS320C6713 DSP
    PDF, 260 Кб, Файл опубликован: 23 сен 2004
    This application report presents a solution for interfacing the ADS8401 and ADS8411 16-bit, parallel interface converters to the TMS320C6713 DSP. The hardware solution consists of existing hardware, specifically the ADS8411EVM, 'C6713 DSK, and 5-6K interface board. The software demonstrates how to use an EDMA ping-pong buffer and Timer1 peripherals to collect data at 2 MSPS. Discussed also are som
  • Using ADS8411 in a Multiplexed Analog Input Application (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 15 фев 2006
    This application report is intended as a guide for using an analog multiplexer to multiplex several input signals to a single high-resolution, high-speed SAR analog-to-digital converter (ADC). The ADC and the multiplexer used were the ADS8411 and the TS5A3159/3359, respectively. This document discusses the important parameters of a multiplexer and defines a few important measurements for evaluatin
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
На английском языке: Datasheet Texas Instruments ADS8401IBPFBTG4
