Оптопары и оптореле Megawin
Datasheet Texas Instruments ADS8201IBRGET — Даташит
СерияADS8201
МодельADS8201IBRGET
2.2V to 5.5V, Low-Power, 12-Bit, 100kSPS, 8-Channel DAS with PGA and SPIв„ў 24-VQFN -40 to 85
2.2V to 5.5V, Low-Power, 12-Bit, 100kSPS, 8-Ch Data Acq System with PGA and SPI datasheet
PDF, 771 Кб, Версия: B, Файл опубликован: 10 май 2010
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
Pin24
Package TypeRGE
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Width (мм)4
Length (мм)4
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
# Input Channels8
Analog Voltage AVDD(Max)(V)5.5
Analog Voltage AVDD(Min)(V)2.2
Approx. Price (US$)2.75 | 1ku
АрхитектураSAR
Digital Supply(Max)(V)5.5
Digital Supply(Min)(V)2.2
INL(Max)(+/-LSB)1.5
Input Range(Max)(V)5.5
Тип входаDifferential
Single-Ended
Integrated FeaturesOscillator
PGA
InterfaceSPI
Operating Temperature Range(C)-40 to 85
Package GroupVQFN
Package Size: mm2:W x L (PKG)24VQFN: 16 mm2: 4 x 4(VQFN)
Power Consumption(Typ)(mW)1.32
Reference ModeExt
Resolution(Bits)12
SINAD(dB)N/A
Sample Rate (max)(SPS)100kSPS
THD(Typ)(dB)N/A
RoHSНе совместим
  • Obtaining 17 Bits of Resolution using a 12-Bit A/D System on a Chip
    PDF, 337 Кб, Файл опубликован: 24 июн 2010
    Integrated data acquisition systems can provide many benefits over discrete component designs. Superior performance, power, and cost savings, along with shorter development times, are among these benefits. Features such as integrated programmable gain amplifiers and averaging can provide added resolution. This application note includes information on how to achieve 17 bits of effective resolution
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8201 (4)
На английском языке: Datasheet Texas Instruments ADS8201IBRGET
