Datasheet ТI UCC25701DTR — Даташит
| Серия | UCC25701 |
| Модель | UCC25701DTR |
Расширенный широтно-импульсный модулятор с режимом напряжения 14-SOIC от -40 до 85
Advanced Voltage Mode Pulse Width Modulator datasheet
PDF, 984 Кб, Версия: C, Файл опубликован: 17 июн 2005
- U-150 Applying the UCC3570 Voltage-Mode PWM Controller to Both Off-LinePDF, 568 Кб, Файл опубликован: 5 сен 1999
The UCC3570 families of pulse-width modulators are for application in isolated switching supplies using primary-side control and a voltage-mode feedback loop. BiCMOS processing provides higher switching frequencies at lower quiescent current drain, while including innovations in both performance and protection features. Its versatility is demonstrated with the description of a 50W, wide input-volt - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UCC25701 (7)
- UCC25701D UCC25701DG4 UCC25701DTR UCC25701N UCC25701NG4 UCC25701PW UCC25701PWG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
