Datasheet Texas Instruments LMV931MFX/NOPB — Даташит
СерияLMV931-N
МодельLMV931MFX/NOPB
Одиночные операционные усилители RRIO 1,8 В 5-SOT-23 от -40 до 125
LMV93x-N Single, Dual, Quad 1.8-V, RRIO Operational Amplifiers datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 7 май 2017
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаA79A
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)60 дБ
CMRR(Typ)86 дБ
GBW(Typ)1.5 МГц
Input Bias Current(Max)35000 pA
Iq per channel(Max)0.23 мА
Iq per channel(Typ)0.116 мА
Количество каналов1
Offset Drift(Typ)5.5 uV/C
Output Current(Typ)65 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)0.42 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)50 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4 мВ
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMV931MFX/NOPB
