Datasheet Texas Instruments LM3405AXMK/NOPB — Даташит
СерияLM3405A
МодельLM3405AXMK/NOPB
1,6 МГц, 1 А, понижающий светодиодный драйвер постоянного тока с внутренней компенсацией 6-SOT-23-THIN от -40 до 125
LM3405A 1.6-MHz, 1-A Constant Current Buck LED Driver With Internal Compensation in Tiny SOT and MSOP-PowerPADв„ў Packages datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 19 сен 2016
Pin6
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY1000
МаркировкаSSEB
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)1 A
Iq(Typ)1.8 мА
Package GroupSOT-23-THIN
Package Size: mm2:W x L6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesEnable/Shutdown,Integrated Switch,Thermal Shutdown
Switching Frequency(Max)1600 kHz
Switching Frequency(Min)1600 kHz
TopologyBuck
ТипConverter,Inductive
Vin(Max)22 В
Vin(Min)3 В
Vout(Max)20 В
Vout(Min)0.2 В
Vref0.205 В
  • Evaluation Modules & Boards: LM3405AEVAL
    1.6MHz, 1A Constant Current Buck LED Driver with Internal Compensation in Tiny SOT-23 Package Evalu
  • Evaluation Modules & Boards: LM3405AXMYEVAL
    LM3405AXMY - 1.6 MHz, 1A Constant Current Buck LED Driver with eMSOP Package EVM
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • Powering & Dimming High-Brightness LEDs w/ LM3405 Constant-Current Buck Reg (Rev. A)
    PDF, 158 Кб, Версия: A, Файл опубликован: 1 май 2013
    This application report describes a few of the many application solutions for the Texas InstrumentsLM3405 LED driver. The LM3405 device is offered in a 6-pin Thin-SOT (SOT) package and operates at aninternal switching frequency of 1.6 MHz, allowing the use of small-value inductors, thereby saving boardspace.
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3405AXMK/NOPB
