Datasheet Texas Instruments ADS7813UB — Даташит
СерияADS7813
МодельADS7813UB
Маломощный последовательный 16-битный аналого-цифровой преобразователь с дискретизацией 16-SOIC от -40 до 85
Low-Power, Serial 16-Bit Sampling Analog-To-Digital Converter datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 13 сен 2005
Pin1616
Package TypeDWDW
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY4040
CarrierTUBETUBE
МаркировкаADS7813UB
Width (мм)7.57.5
Length (мм)10.310.3
Thickness (мм)2.352.35
Pitch (мм)1.271.27
Max Height (мм)2.652.65
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)4.75 В
INL(Max)2 +/-LSB
Input Range(Max)10 В
Input Range(Min)-10 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Multi-Channel ConfigurationN/A
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Power Consumption(Typ)35 mW
Reference ModeExt,Int
Разрешение16 Bits
SINADN/A дБ
SNR89 дБ
Sample Rate (max)40kSPS SPS
Sample Rate(Max)0.04 MSPS
THD(Typ)-98 дБ
  • Upgrading from the ADS7813 to the ADS8513
    PDF, 85 Кб, Файл опубликован: 3 дек 2007
    This application report applies to current designs using the Texas Instruments ADS7813 device in a surface-mount SO-16 (DW) package. This document guidesusers of the ADS78xx device, with regards to potential compatibility issues that can be encountered when upgrading to the new ADS85xx part series.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7813UB
