Datasheet Texas Instruments MSP430TCH5EPW — Даташит
СерияMSP430TCH5E
МодельMSP430TCH5EPW
Устройство с поддержкой Haptics, аутентифицированное для использования технологии Immersion Touchsense 28-TSSOP от -40 до 85
MSP430TCH5E Haptics-Enabled Mixed-Signal Microcontroller datasheet
PDF, 1.4 Мб, Файл опубликован: 9 дек 2013
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
Маркировка430TCH5E
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
  • Evaluation Modules & Boards: DRV2603EVM-CT
    DRV2603 Evaluation Module
  • Evaluation Modules & Boards: DRV8601ZQVEVM
    DRV8601ZQVEVM Evaluation Module
  • Evaluation Modules & Boards: DRV2605EVM-CT
    DRV2605EVM-CT ERM/LRA Haptic Driver Evaluation
  • Evaluation Modules & Boards: MSP-TS430PW28A
    MSP-TS430PW28A - 28-pin Target Development Board for MSP430F2x and MSP430G2x MCUs
    MSP EnergyTrace Technology
  • Haptics and Capacitive Touch Using the MSP430TCH5E: the HapTouch BoosterPack
    PDF, 2.2 Мб, Файл опубликован: 9 дек 2013
  • 10-cm Capacitive Proximity Detection With MSP430 Microcontrollers (Rev. A)
    PDF, 1.8 Мб, Версия: A, Файл опубликован: 8 июл 2013
    The PinOsc feature of the MSP430 microcontroller value line family provides a simple and straight forward mechanism to measure capacitance. The PinOsc feature not only allows for touch detection but also provides enough sensitivity to support proximity applications. This application report demonstrates a 10+-cm proximity detection BoosterPack design solution. The software uses the PinOsc feature a
  • Wireless Remote Controller With Capacitive Touch Pad Using MSP430F51x2 (Rev. A)
    PDF, 2.7 Мб, Версия: A, Файл опубликован: 17 май 2012
    This application report describes the implementation of a two-dimensional capacitive touch pad, using the high-resolution Timer D of the MSP4305132 MCU.
  • Capacitive Touch Sensing and SYS/BIOS
    PDF, 324 Кб, Файл опубликован: 12 сен 2012
    SYS/BIOS is designed for use in embedded applications that need real-time scheduling, synchronization, and instrumentation. It provides preemptive multitasking, hardware abstraction, and memory management.This application report uses an adaptation of the capacitive touch library to interface with SYS/BIOS. Thisinterface abstracts the capacitive touch interface, promoting use of the graphical c
  • Capacitive Touch Sensing, MSP430 Button Gate Time Optimization and Tuning Guide
    PDF, 1.1 Мб, Файл опубликован: 21 май 2013
    MSP430в„ў microcontroller based capacitive touch buttons can offer increased performance when properly optimized and tuned for their specific application. Performance benefits that result from button optimization can include, but are not limited to, decreased power consumption, improved response time, and the ability to grow a design to include more buttons. This application report provides th
  • Capacitive Touch Sensing, MSP430 Slider and Wheel Tuning Guide
    PDF, 1.0 Мб, Файл опубликован: 21 май 2013
    This application report provides guidelines on how to tune capacitive touch sliders and wheels running on the MSP430в„ў microcontrollers. It identifies the hardware and software parameters as well as explains the steps used in tuning sliders and wheels.The slider and wheel tuning is based on the APIs defined within the Capacitive Touch Sense Library (CAPSENSELIBRARY).
  • Capacitive Touch Hardware Design Guide (Rev. A)
    PDF, 784 Кб, Версия: A, Файл опубликован: 17 ноя 2015
    Capacitive touch detection is sometimes considered more art than science. This often results in multiple design iterations before the optimum performance is achieved. There are, however, good design practices for circuit layout and principles of materials that need to be understood to keep the number of iterations to a minimum. This design guide describes a process for creating and designing capac
  • 1-uA Capacitive Grip Detection Based on MSP430 Microcontrollers (Rev. B)
    PDF, 373 Кб, Версия: B, Файл опубликован: 14 авг 2013
    This application report discusses how to design a simple and ultra low-power grip detector BoosterPack for the MSP430 LaunchPadв„ў. The PINOSC feature in every msp430G2xx2 and msp430G2xx3 device makes it possible to eliminate all the external components when implementing a capacitive touch design. All the components used in the grip detector, such as capacitive sensors, LEDs are all integrate
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430TCH5EPW
