Datasheet Texas Instruments TPS7A4515DCQT — Даташит
СерияTPS7A45
МодельTPS7A4515DCQT
Малошумящий стабилизатор напряжения с быстрым переходным процессом, 1,5 А и малым падением напряжения 6-SOT-223
TPS7A45xx Low-Noise Fast-Transient-Response 1.5-A Low-Dropout Voltage Regulators datasheet
PDF, 2.7 Мб, Версия: F, Файл опубликован: 18 ноя 2015
Pin6
Package TypeDCQ
Industry STD TermSOT-223
Package QTY250
CarrierSMALL T&R
МаркировкаPS7A4515
Width (мм)3.5
Length (мм)6.5
Thickness (мм)1.6
Max Height (мм)1.8
Точность2.5 %
Fixed Output Options1.5,1.8,2.5,3.3 В
Iout(Max)1.5 A
Iq(Typ)1 мА
Noise35 uVrms
Output Capacitor TypeCeramic
PSRR @ 100KHz38 дБ
Package GroupSOT-223
Package Size: mm2:W x L6SOT-223: 46 mm2: 7.06 x 6.5(SOT-223) PKG
Regulated Outputs1
Special FeaturesEnable,Reverse Current Protection
Thermal Resistance ОёJA28 В°C/W
Vdo(Typ)300 мВ
Vin(Max)20 В
Vin(Min)2.1 В
Vout(Max)20 В
Vout(Min)1.5 В
  • Evaluation Modules & Boards: TPS7A4533EVM-385
    TPS7A4533EVM-385 Evaluation Module
  • Evaluation Modules & Boards: TPS7A4515EVM-385
    TPS7A4515EVM-385 Evaluation Module
  • Evaluation Modules & Boards: TPS7A4501EVM-385
    TPS7A4501EVM-385 Evaluation Module
  • Evaluation Modules & Boards: TPS7A4525EVM-385
    TPS7A4525EVM-385 Evaluation Module
  • Evaluation Modules & Boards: TPS7A4518EVM-385
    TPS7A4518EVM-385 Evaluation Module
  • Evaluation Modules & Boards: TPS7A4501EVM-CVAL
    TPS7A4501-SP Low Drop Out (LDO) Evaluation Module
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TPS7A4515DCQT
