Datasheet Texas Instruments SN74LVC1G38YZPR — Даташит
СерияSN74LVC1G38
МодельSN74LVC1G38YZPR
Один вентиль NAND с 2 входами и выходом с открытым стоком 5-DSBGA от -40 до 85
SN74LVC1G38 Single 2-Input NAND Gate With Open-Drain Output datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 3 авг 2017
40 предложений от 18 поставщиков
Интегральные микросхемы Логические микросхемы - Затворы и Инверторы
SN74LVC1G38YZPR
9.72 ₽
Hi-Tech Circuit Group
SN74LVC1G38YZPR
ТаймЧипс
SN74LVC1G38YZPR
SUV System
SN74LVC1G38YZPR
Pin5
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаD7N
Width (мм)1.25
Length (мм)1.75
Thickness (мм).31
Pitch (мм).5
Max Height (мм).5
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeNAND
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupDSBGA
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyNAND Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)10,6,4.5,3.9 нс
  • Designing and Manufacturing with TI's X2SON Packages
    PDF, 134 Кб, Файл опубликован: 23 авг 2017
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G38YZPR
