Datasheet ТI LM1084IS-5.0/NOPB — Даташит
СерияLM1084
МодельLM1084IS-5.0/NOPB
Datasheet Texas Instruments LM1084IS-5.0/NOPB
Линейный стабилизатор с фиксированным/регулируемым выходом 5 А 3-DDPAK/TO-263 от -40 до 125
LM1084 5-A Low Dropout Positive Regulators datasheet
PDF, 2.2 Мб, Версия: G, Файл опубликован: 9 янв 2015
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
LM1084IS5.0/NOPB, LM1084IS 5.0/NOPB
На английском языке: Datasheet Texas Instruments LM1084IS-5.0/NOPB
Политика конфиденциальности
