Datasheet Texas Instruments OPA4820IDG4 — Даташит
СерияOPA4820
МодельOPA4820IDG4
Счетверенный малошумящий операционный усилитель с единичным усилением и обратной связью по напряжению 14-SOIC от -40 до 85
Quad, Unity-Gain, Low-Noise, Voltage-Feedback Operational Amplifier datasheet
PDF, 840 Кб, Версия: D, Файл опубликован: 28 авг 2008
Pin14
Package TypeD
Package QTY50
МаркировкаOPA4820
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic84 dBc
3rd Harmonic92 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl650 МГц
CMRR(Min)76 дБ
CMRR(Typ)85 дБ
GBW(Typ)650 МГц
Input Bias Current(Max)20000000 pA
Iq per channel(Max)5.85 мА
Iq per channel(Typ)5.6 мА
Количество каналов4
Offset Drift(Typ)4 uV/C
Output Current(Typ)85 мА
Rail-to-RailNo
Slew Rate(Typ)240 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2.5 нВ/rtГц
Vn at Flatband(Typ)2.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.8 мВ
  • Evaluation Modules & Boards: DEM-OPA-SO-4A
    DEM-OPA-SO-4A
  • Evaluation Modules & Boards: DEM-OPA-TSSOP-4A
    DEM-OPA-TSSOP-4A
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
На английском языке: Datasheet Texas Instruments OPA4820IDG4
