Datasheet ТI TPS61160ADRVR — Даташит
| Серия | TPS61160A |
| Модель | TPS61160ADRVR |
Драйвер белого светодиода с ШИМ-регулированием яркости в корпусе размером 2 x 2 мм.
TPS6116xA White LED Driver with PWM Brightness Control in 2-mm x 2-mm WSON Package datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 14 июл 2016
До 10 светодиодов в серии 6-WSON от -40 до 85
- TPS6116x With Separate Power Stage and IC Input VoltagesPDF, 194 Кб, Файл опубликован: 2 апр 2009
This application report shows how to operate the TPS6116x integrated circuits (IC) with two separate input power rails, one for the boost power stage and one to power the IC itself. In this example, an input as low as 1.8 V from discharged dual-alkaline batteries supplies power to the boost stage, whereas a separate 3.3-V supply powers the IC. - How to Use Analog Dimming With TPS6116xPDF, 162 Кб, Файл опубликован: 5 авг 2011
The TPS6116x family of devices are simple, white LED drivers that can drive up to 10 LEDs in series. The CTRL pin on these devices is the input for the integrated analog dimming circuitry but can only be used for PWM signals switching higher than 5 kHz. This application report shows a simple, external circuit that can be used to perform analog dimming from PWM signals that are below 5 kHz as well - Extending the Input Voltage Range of the TPS6116x/8x/9x WLED DriversPDF, 124 Кб, Файл опубликован: 12 авг 2009
The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available - Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61160A (2)
- TPS61160ADRVR TPS61160ADRVT
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
