Datasheet Texas Instruments TPA3116D2QDADRQ1 — Даташит
СерияTPA3116D2-Q1
МодельTPA3116D2QDADRQ1
2-канальный аудиоусилитель класса D с аналоговым входом, 50 Вт, 32-HTSSOP от -40 до 125
TPA311xD2-Q1 100-W and 50-W Class-D Stereo Automotive Amplifiers datasheet
PDF, 2.0 Мб, Версия: B, Файл опубликован: 5 окт 2016
Pin323232
Package TypeDADDADDAD
Industry STD TermHTSSOPHTSSOPHTSSOP
Package QTY200020002000
CarrierLARGE T&RLARGE T&RLARGE T&R
Маркировка3116QTPAD2
Width (мм)6.26.26.2
Length (мм)111111
Thickness (мм)1.151.151.15
Pitch (мм).65.65.65
Max Height (мм)1.21.21.2
Analog Supply (V)26 Min
Audio Input TypeAnalog
Closed/Open LoopClosed
Control InterfaceHardware
Package GroupHTSSOP
Package Size: mm2:W x L32HTSSOP: 68 mm2: 6.2 x 11(HTSSOP) PKG
Power Stage Supply(Max)26 В
Power Stage Supply(Min)4.5 В
Power to Bridge Tied Load(Max)50 W
RatingAutomotive
Speaker Channels2 Max
Supported Bridge Tied Load(Min)3.2 Ohms
  • Evaluation Modules & Boards: TPA3116D2EVM
    50-W Stereo Analog Input Class-D Audio Amplifier Evaluation Module
  • Class-D LC Filter Design (Rev. B)
    PDF, 488 Кб, Версия: B, Файл опубликован: 20 фев 2015
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3116D2-Q1 (1)
  • TPA3116D2QDADRQ1
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3116D2QDADRQ1
