Datasheet Texas Instruments LMH6626MMX/NOPB — Даташит
СерияLMH6626
МодельLMH6626MMX/NOPB
Одиночный/двойной сверхмалошумящий широкополосный операционный усилитель 8-VSSOP от -40 до 125
LMH6624 and LMH6626 Single/Dual Ultra Low Noise Wideband Operational Amplifier datasheet
PDF, 1.9 Мб, Версия: G, Файл опубликован: 19 дек 2014
Package TypeDGK
Industry STD TermVSSOP
Package QTY3500
МаркировкаA98A
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic(dBc)65
3rd Harmonic(dBc)80
@ MHz10
Acl, min spec gain(V/V)10
Additional FeaturesDecompensated
Approx. Price (US$)2.64 | 1ku
АрхитектураBipolar
Voltage FB
BW @ Acl(MHz)80
CMRR(Min)(dB)87
CMRR(Typ)(dB)95
GBW(Typ)(MHz)1600
Input Bias Current(Max)(pA)20000000
Iq per channel(Max)(mA)16
Iq per channel(Typ)(mA)12
Number of Channels(#)2
Offset Drift(Typ)(uV/C)0.25
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)100
Package GroupVSSOP
Package Size: mm2:W x L (PKG)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
Rail-to-RailNo
Slew Rate(Typ)(V/us)360
Total Supply Voltage(Max)(+5V=5, +/-5V=10)12
Total Supply Voltage(Min)(+5V=5, +/-5V=10)5
Vn at Flatband(Typ)(nV/rtHz)1
Vos (Offset Voltage @ 25C)(Max)(mV)0.5
  • Evaluation Modules & Boards: LMH730123
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin MSOP Package
  • Evaluation Modules & Boards: LMH730036
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin SOIC Package
  • AN-1604 Decompensated Operational Amplifiers (Rev. B)
    PDF, 206 Кб, Версия: B, Файл опубликован: 1 май 2013
    This application report discusses the what, why, and where of decompensated op amps. This applicationreport also describes external compensation techniques, such as reducing loop gain, to stabilize op ampsoperated at gains less than the minimum stable gain specified in the datasheet. A comprehensivetreatment of input lead-lag compensation including examples is presented.
  • OA-14 Improving Amplifier Noise for High 3rd Intercept Amplifiers (Rev. F)
    PDF, 594 Кб, Версия: F, Файл опубликован: 1 май 2013
    This application report discusses improving Amplifier Noise for High 3rd Intercept Amplifiers.
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
  • OA-15 Frequent Faux Pas in Applying Wideband Current Feedback Amplifiers (Rev. C)
    PDF, 365 Кб, Версия: C, Файл опубликован: 17 апр 2013
    As op amp operating speeds have moved to ever higher frequencies, a whole new set of design concernshave come into play for linear op amp applications. With the development of the current feedbacktopology, design concerns unique to that topology must also be considered if optimal performance is to beachieved from devices offering over 200 MHz в€’3 dB bandwidths. This application report reviews
Серия: LMH6626 (4)
На английском языке: Datasheet Texas Instruments LMH6626MMX/NOPB
