Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVC1G3157DRYR — Даташит
СерияSN74LVC1G3157
МодельSN74LVC1G3157DRYR
Однополюсный двухпозиционный аналоговый переключатель 6-SON от -40 до 125
SN74LVC1G3157 Single-Pole Double-Throw Analog Switch datasheet
PDF, 1.9 Мб, Версия: L, Файл опубликован: 16 май 2017
Pin6
Package TypeDRY
Industry STD TermUSON
JEDEC CodeR-PDSO-N
Package QTY5000
МаркировкаC5
Width (мм)1
Length (мм)1.45
Thickness (мм).5
Pitch (мм).5
Max Height (мм).6
Additional FeaturesBreak-before-make
Полоса частот340 МГц
Configuration2:1 SPDT
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)5.2 пФ
Input/Output ON-state Capacitance(Typ)17.3 пФ
Количество каналов1
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Ron(Max)50 Ohms
Ron(Typ)6 Ohms
Supply Current(Max)35 uA
Supply Current(Typ)1 uA
Supply Range5.5 Max
VIH(Min)vcc*.7 В
VIL(Max)vcc*.3 В
Vdd(Max)5.5 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
На английском языке: Datasheet Texas Instruments SN74LVC1G3157DRYR
