Datasheet Texas Instruments TPS56300PWPR — Даташит
СерияTPS56300
МодельTPS56300PWPR
Контроллеры с двойным выходом, низким входным напряжением и секвенированием 28-HTSSOP
Dual Output Low-Input-Voltage DSP Power Supply Controller with Sequencing datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 20 мар 2002
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPS56300
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementLM26420XMH/NOPB
Replacement CodeF
  • Using the TPS56300 for Powering DSPs (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 16 янв 2001
    The synchronous buck converter controllers (TPS56100, TPS56300, TPS56xxx, and TPS5602) made by Texas Instruments are specifically designed to provide excellent transient response and high efficiency to the microprocess power applications such as the TMS320C6000 and TMS320C5000 families from TI, as well as similar digital loads. In addition, hysteresis control method is used such that power supply
  • Voltage Regulator Solutions for Xilinx Virtex E Dual Voltage FPGAs
    PDF, 77 Кб, Файл опубликован: 13 июн 2000
    This application report serves as a reference for engineers designing with Xilinix 2.5-V and 1.8-V Virtex multivoltage FPGA products. It provides basic information on the issues facing engineers not experienced with multivoltage type products.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
Серия: TPS56300 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS56300PWPR
