Datasheet Texas Instruments TM4C1299NCZADT3R — Даташит
СерияTM4C1299NCZAD
МодельTM4C1299NCZADT3R
Поддержка Интернета вещей.
Tiva C Series TM4C1299NCZAD Microcontroller Data Sheet datasheet
PDF, 10.5 Мб, Версия: B, Файл опубликован: 19 июн 2014
Высокопроизводительный 32-битный микроконтроллер на базе ARM® Cortex®-M4F 212-NFBGA от -40 до 105.
Pin212212
Package TypeZADZAD
Package QTY10001000
Маркировка9NCZADT3TM4C129
Width (мм)1010
Length (мм)1010
Thickness (мм).65.65
10/100 ENET MACNo
10/100 ENET MAC+PHYYes
ADC Channels24
ADC Resolution12 Bits
Bi- and Quad- SSI/SPIYes
CAN MAC2
CPUARM Cortex-M4F
EEPROM6 KB
External Peripheral InterfaceYes
Flash1024 KB
Тактовая частота120 МГц
GPIO140
I2C10
I2SNo
LCDYes
LCD ControllerYes
Max Speed120 МГц
Motion PWM Outputs8
Non-volatile Memory6 KB
Рабочий диапазон температурот -40 до 105,-40 до 85 C
Package GroupNFBGA
Package Size: mm2:W x L212NFBGA: 100 mm2: 10 x 10(NFBGA) PKG
Pin & Package212BGA
Pin/Package212NFBGA
QEI1
RAM256 KB
RTCYes
SPI4
SRAM256 kB
SSI/SPI4
SecurityNo HW accelerator
SysTickYes
UART8
USB D, H/D, or OTGOTG
USB High-Speed with ULPIYes
Watchdog Timers2
  • Development Kits: DK-TM4C129X
    IoT Enabled ARMВ® CortexВ®-M4F MCU TM4C129X Connected Development Kit
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-ARM
    XDS100v2 JTAG Debug Probe (ARM version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Serial to Ethernet Converter for TM4C129x Microcontrollers Using RTOS
    PDF, 1.5 Мб, Файл опубликован: 31 мар 2015
    Some legacy products may only contain a serial port and accessing such products is increasingly becoming a challenge due to the inability to add multiple such products to a shared network and the inability to access the legacy product from long distances. A serial-to-Ethernet converter provides a simple solution to solve the above challenges. The software described in this application report allow
  • Differences Between Stellaris Tempest & Firestorm-Class MCUs and Tiva TM4C129x
    PDF, 162 Кб, Файл опубликован: 22 окт 2013
    This document addresses design considerations when migrating working designs from Tempest- and Firestorm-class Stellaris microcontrollers to Tiva TM4C129x microcontrollers. Topics covered include both software and hardware differences as well as feature changes and enhancements. All software differences are comprehended in the Driver Library APIs that are part of StellarisWareВ® and TivaWare&tr
  • Implementing OPUS Voice Code for TM4C129x Device
    PDF, 3.1 Мб, Файл опубликован: 20 июн 2016
    Opus is an open source, royalty-free audio compression format developed by Xiph and standardized by the IETF. It utilizes lossy compression which is designed to efficiently code audio with a low latency making it suitable for real time communication. Opus replaces both the Vorbis and Speex codecs, and is intended for storage and streaming applications. Its low complexity allows it to be run effici
  • Using Feature Set of I2C on TM4C129x Microcontrollers
    PDF, 1.7 Мб, Файл опубликован: 28 июл 2015
    The inter-integrated circuit (I2C) is a multi-master, multi-slave, single-ended bus that is typically used forattaching lower speed peripheral ICs to processors and microcontrollers. The type of slave devices range from non-volatile memory to data-acquisition devices like analog-to-digital converters (ADC), sensors, and so forth. This application report demonstrates how to use the feature rich I
  • Differences Between Tiva C Series TM4C Microcontrollers
    PDF, 121 Кб, Файл опубликован: 22 окт 2013
    This document addresses design considerations when migrating working designs between Tiva C Series TM4C123x and TM4C129x microcontrollers. While most modules shared among the devices are largely the same, some feature enhancements are worth noting. This document describes software and hardware differences for both feature changes and enhancements. All software differences are comprehended in the T
  • 1-Wire Enumeration (Rev. B)
    PDF, 93 Кб, Версия: B, Файл опубликован: 26 апр 2016
    application report describes the 1-Wire communication protocol, available TivaWareв„ў for C Series APIs for the 1-Wire module in Tivaв„ў C Series microcontrollers and an example enumeration algorithm using binary tree search.
  • System Design Guidelines for the TM4C129x Family of Tiva C Series MCUs
    PDF, 1.4 Мб, Файл опубликован: 16 июл 2013
    TM4C129x MCUs Tivaв„ў C Series TM4C129x System Design Guidelines
  • Diagnosing Software Faults in StellarisВ® Microcontrollers
    PDF, 1.9 Мб, Файл опубликован: 4 июн 2012
    During typical development efforts, system operation can sometimes end up in a fault handler. At first glance, faults might seem cryptic or difficult to understand, but Stellaris microcontrollers include several features to help determine why a fault occurred. Read this application note to learn about the fault handling capabilities of Stellaris microcontrollers, how to diagnose faults, and how to
  • Migrating Software Projects from StellarisWare to TivaWare for C Series Software (Rev. A)
    PDF, 92 Кб, Версия: A, Файл опубликован: 1 май 2013
    As TI launches the Tivaв„ў family of 32-bit ARMВ® Cortexв„ў-M4 microcontrollers (MCUs), the StellarisWareВ® suite of comprehensive software tools is also migrating to TivaWareв„ў. This new software platform offers the same features found in earlier versions, but a few changes have been made in the migration process that require simple modifications to be made in existing StellarisWare applications in orde
  • Transitioning Designs From Stellaris LM3S Microcontrollers to Tiva C Series MCUs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 22 окт 2013
    This application report addresses design considerations when migrating working designs from Stellaris LM3S microcontrollers to Tiva C Series microcontrollers. Topics covered include software and hardware considerations as well as feature changes and enhancements. Software migration is very straightforward when using the Driver Library APIs in the StellarisWareВ® and TivaWareв„ў for C Series
  • StellarisВ® Graphics Library Display Drivers (AN01287) (Rev. A)
    PDF, 67 Кб, Версия: A, Файл опубликован: 9 июл 2013
    The Stellaris Graphics Library (grlib) offers a compact yet powerful collection of graphics functions allowing the development of compelling user interfaces on small monochrome or color displays attached to Stellaris microcontrollers. This application report describes how to support a new display device in the Stellaris Graphics Library.
  • Using the CMSIS DSP Library in Code Composer Studio for TM4C MCUs (Rev. G)
    PDF, 3.0 Мб, Версия: G, Файл опубликован: 7 окт 2015
    This application report describes the process required to build the ARMВ® CMSIS DSP library in Code Composer Studio v6.1 with ARM Compiler version up to 5.2.5. This document also describes how to use Code Composer Studio v6.1 to build, run, and verify the 11 ARM DSP example projects that are included in the CMSIS package.
  • System Design Guidelines for the TM4C123x Family of Tiva C Series MCUs
    PDF, 1.5 Мб, Файл опубликован: 31 июл 2013
  • Dual-SPI Emulating IВІS on Tivaв„ў C Series TM4C123x MCUs (Rev. B)
    PDF, 436 Кб, Версия: B, Файл опубликован: 12 июн 2013
    This application report presents an example using two serial peripheral interfaces (SPIs) to emulate an integrated interchip sound (I2S) peripheral on the StellarisВ® LM4F232 (Tiva C series TM4C123GH6PGE) microcontroller. Utilizing the sound API, .wav audio files stored in the on-board SD card are played via pseudo-I2S to an external Texas Instruments' TLV320AIC3107 codec. This generic software pla
  • Powering Cortex-M4 MCUs Using the High Efficiency DCS-Control Topology
    PDF, 164 Кб, Файл опубликован: 3 фев 2013
    The new Tiva C Series ARMВ® Cortexв„ў-M4 family of versatile microcontrollers provides prolific connectivity peripherals, such as the industry's first integrated Ethernet MAC and PHY, advanced analog integration and hardware floating-point performance. This application report presents an ultra-low IQ (4.8 ОјA) power supply solution for Tiva C Series devices using the TPS62177, a high efficiency synchr
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > TM4C12x
На английском языке: Datasheet Texas Instruments TM4C1299NCZADT3R
