Datasheet Texas Instruments LM25575MH/NOPB — Даташит
СерияLM25575
МодельLM25575MH/NOPB
Понижающий импульсный стабилизатор постоянного/постоянного тока от 6 В до 42 В, 1,5 А 16-HTSSOP от -40 до 125
LM25575 42-V, 1.5-A Step-Down Switching Regulator datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 24 авг 2017
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаMHL25575
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)95 %
Iout(Max)1.5 A
Iq(Typ)1 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesFrequency Synchronization
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)6 В
Vout(Max)40 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: LM25575EVAL
    Evaluation Board for LM25575, 42V, 1.5A Step-Down Switching Regulator
  • Quick Start Guide for a 3 Amp Buck Regulator Using the LM5576 and LM25576 (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides an easy to use process to design a 3 Amp buck regulator using the LM5576and LM25576 switching regulators.
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • WEBENCHВ® Power Architect Project Report
    PDF, 206 Кб, Файл опубликован: 17 фев 2012
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Quick Start Guide for a 1.5 Amp Buck Regulator Using the LM5575 and LM25575 (Rev. B)
    This application note provides an easy to use process to help users design a 1.5 Amp buck regular usingthe LM5575 and LM25575 switching regulators.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LM25575 (3)
На английском языке: Datasheet Texas Instruments LM25575MH/NOPB
