Datasheet Texas Instruments TMS320VC5409ZGU100 — Даташит
СерияTMS320VC5409
МодельTMS320VC5409ZGU100
Процессор цифровых сигналов с фиксированной точкой (DSP) 144-BGA MICROSTAR от -40 до 100
TMS320VC5409 Fixed-Point Digital Signal Processor datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 20 окт 2008
Pin144144
Package TypeZGUZGU
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeS-PBGA-NS-PBGA-N
Маркировка100DVC5409ZGU
Width (мм)1212
Length (мм)1212
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
    XDS200 USB Debug Probe
  • TMS320VC5409 Bootloader Technical Reference (Rev. A)
    PDF, 280 Кб, Версия: A, Файл опубликован: 26 мар 2002
    This document describes the features and operation of the TMS320VC5409 bootloader. The contents of the on-chip ROM also are discussed.Important Notice Regarding Bootloader Program Contents:Texas Instruments may periodically update the bootloader code supplied in the ROM to correct known problems, provide additional features, or improve functionality. These changes may be made without
  • Migrating from TMS320VC549 to TMS320VC5409 (Rev. C)
    PDF, 77 Кб, Версия: C, Файл опубликован: 12 фев 2002
    This document describes issues of interest related to migration from the TMS320VC549 to the TMS320VC5409. The objective of this document is to indicate differences between the two devices. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, refer to the device data sheets and/or the TMS320C54x DSP CPU and Perip
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
На английском языке: Datasheet Texas Instruments TMS320VC5409ZGU100
