Datasheet Texas Instruments UC3823BDWG4 — Даташит
СерияUC3823B
МодельUC3823BDWG4
Высокоскоростной ШИМ-контроллер 16-SOIC от 0 до 70
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Pin16
Package TypeDW
Package QTY40
МаркировкаUC3823BDW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCurrent
Duty Cycle(Max)100 %
Frequency(Max)1000 kHz
Gate Drive(Typ)2 A
Special FeaturesError Amplifier,Leading Edge Blanking,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward
UVLO Thresholds On/Off16/10 В
Vin(Max)22 В
Vin(Min)16 В
  • U-160 Simple Circuit Modifications Enhance Optocoupler Performance
    PDF, 240 Кб, Файл опубликован: 5 сен 1999
    The optocoupler is often used in pulse-width-modulated power converters to transmit an error signal across an isolation boundary. This error signal is used on the primary side to close the control loop. This application note describes a typical optocoupler feedback scheme using the UC3965 Precision Reference with Low-Offset Error Amplifier and a Siemens Optoelectronics IL207 optocoupler. The discu
  • U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM Controllers
    PDF, 204 Кб, Файл опубликован: 5 сен 1999
    The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
Серия: UC3823B (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3823BDWG4
