Datasheet Texas Instruments TMS320C6452ZUT9 — Даташит
СерияTMS320C6452
МодельTMS320C6452ZUT9
Процессор цифровых сигналов 529-FCBGA от 0 до 90
TMS320C6452 Digital Signal Processors datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 10 апр 2012
Pin529529529
Package TypeZUTZUTZUT
Industry STD TermFCBGAFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY848484
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320C6452ZUT900MHZ@2007 TI
Width (мм)191919
Length (мм)191919
Thickness (мм)2.652.652.65
Pitch (мм).8.8.8
Max Height (мм)3.33.33.3
DSP1 C64x+
  • Evaluation Modules & Boards: TMDXEVM6452
    C6452 DSP Evaluation Module
    XDS200 USB Debug Probe
  • Using the TMS320C6452 Bootloader (Rev. A)
    PDF, 307 Кб, Версия: A, Файл опубликован: 1 июн 2009
    This document describes the functionality of the TMS320C6452 ROM bootloader software. The ROM bootloader resides in the ROM of the device beginning at ROM address 0x00100000. The ROM boot loader (RBL) implements methods for booting in the listed modes. It reads the contents of the BOOTCFG register to determine boot mode and performs appropriate commands to effect boot of device. If an improper boo
  • Implementing DDR2 PCB Layout on the TMS320C6452 DMSoC (Rev. A)
    PDF, 149 Кб, Версия: A, Файл опубликован: 25 мар 2008
    This application report contains implementation instructions for the DDR2 interface contained on the TMS320C6452 digital signal processor (DSP) device. The approach to specifying interface timing for the DDR2 interface is quite different than on previous devices.The previous approach specified device timing in terms of data sheet specifications andsimulation models. The system designer was re
  • TMS320C6452 Power Consumption Summary (Rev. C)
    PDF, 132 Кб, Версия: C, Файл опубликован: 6 янв 2010
    NOTE: PRELIMINARY DATA FOR TMX DEVICES. INFORMATION SUBJECT TO CHANGEThis application report discusses power consumption of the Texas Instruments TMS320C6452 Digital Signal Processor (DSP). Power consumption is highly application-dependent, so a spreadsheet is provided to model power consumption for your applications.
  • Error Detection and Correction Mechanism of TMS320C64x+/C674x (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 19 июл 2013
    This application report describes the error detection and correction mechanism of the C64x+/C674x megamodule L1P and L2 memories implemented on some devices. Depending on the type of application, these mechanisms are used to either provide diagnostic measures to detect faults in the memory that could lead to unacceptable risk for the user or to increase the availability of the system.
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
Серия: TMS320C6452 (2)
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMS320C6452ZUT9
