Datasheet ТI UCC383T-ADJ — Даташит
СерияUCC383
МодельUCC383T-ADJ
Datasheet Texas Instruments UCC383T-ADJ
Линейные регуляторы с низким падением напряжения, 3 А, 5-TO-220, от 0 до 70
UCC283-x, UCC383-x: Low-Dropout 3-A Linear Regulator Family datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 23 фев 2004
  • Using LDOs and Power Managers in Systems with Redundant Power Supplies
    PDF, 58 Кб, Файл опубликован: 29 ноя 2000
    For reasons of continuity in some systems, independent power sources must operate in parallel. The traditional way to connect two ore more power sources in parallel uses isolation diodes. However, in situations where the associated voltage drop or the presence of voltage-feedback sensing wires makes using isolation diodes undesirable, special types of low dropout voltage regulators (LDOs) and hot-
  • High Current LDO Linear Reglators (UCCx81-ADJ, UCx82-ADJ, UCCx83-ADJ, UCx85-AD
    PDF, 56 Кб, Файл опубликован: 7 май 2002
    This application provides an overview of the UCCx81-ADJ, UCCx82-ADJ, UCCx83-ADJ, UCCx84-ADJ, and UCcx85-ADJ devices.
UCC383TADJ, UCC383T ADJ
На английском языке: Datasheet Texas Instruments UCC383T-ADJ
Политика конфиденциальности
