Datasheet Texas Instruments P82B96DG4 — Даташит
| Серия | P82B96 |
| Модель | P82B96DG4 |
Двойной двунаправленный буфер шины 8-SOIC от -40 до 85
P82B96 I2C Compatible Dual Bidirectional Bus Buffer datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 14 май 2017
Купить P82B96DG4 на РадиоЛоцман.Цены — от 81 до 427 ₽12 предложений от 12 поставщиков IC REDRIVER I2C 1CH 400KHZ 8SOIC. Buffer, ReDriver 1 Channel 400kHz 8-SOIC. Interface - Signal Buffers, Repeaters, Splitters | |||
| P82B96DG4 Texas Instruments | 81 ₽ | ||
| P82B96DG4 Texas Instruments | 246 ₽ | ||
| P82B96DG4 Texas Instruments | по запросу | ||
| P82B96DG4 | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 75 |
| Carrier | TUBE |
| Маркировка | PG96 |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Channel Width | 2 |
| Master Side I2C Bus Capacitance Supported | 400 пФ |
| Max Frequency | 400 kHz |
| Количество выходов | 2 |
| Package Group | SOIC |
| Slave Side I2C Bus Capacitance Supported | 4000 пФ |
| Special Features | Open-Drain I/O Type |
| VCC(Max) | 15 В |
| VCC(Min) | 2 В |
| fSCLK(Max) | 0.4 МГц |
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: P82B96 (11)
- Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
