Клеммники KEEN SIDE
Datasheet Texas Instruments LM3533TMX-40A/NOPB — Даташит
СерияLM3533
МодельLM3533TMX-40A/NOPB
Комплексное световое решение для смартфонов 20-DSBGA от -40 до 125
LM3533 Complete Lighting Power Solution for Smartphone Handsets datasheet
PDF, 1.8 Мб, Версия: C, Файл опубликован: 27 сен 2015
Pin20
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаD74B
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Количество каналов7
Duty Cycle(Max)94 %
LED25
LED Current Per Channel30 мА
Package GroupDSBGA
Peak Efficiency88 %
Shutdown Current(Typ)1 uA
Special FeaturesOVP
Switching Frequency(Max)1000 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)40 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: LM3533EVAL
    LM3533 Evaluation Module
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
LM3533TMX40A/NOPB, LM3533TMX 40A/NOPB
На английском языке: Datasheet Texas Instruments LM3533TMX-40A/NOPB
