Datasheet Texas Instruments DAC8168IAPW — Даташит
| Серия | DAC8168 |
| Модель | DAC8168IAPW |
14-Bit, Octal Channel, Ultra-Low Glitch, Voltage Output DAC with 2.5V, 2ppm/В°C Internal Reference 14-TSSOP -40 to 125
12-/14-/16-Bit, Octal Channel, Ultralow Glitch, Voltage Output DACs w/Int Ref datasheet
PDF, 2.3 Мб, Версия: E, Файл опубликован: 8 янв 2014
Купить DAC8168IAPW на РадиоЛоцман.Цены — от 417 до 3 345 ₽35 предложений от 19 поставщиков Микросхема Преобразователь DA, 14Bit, Octal Channel, Ultra-Low Glitch, Voltage Output DAC with 2.5V, 2ppm/℃ Internal Reference 14-TSSOP -40℃ to 125℃ | |||
| DAC8168IAPW Texas Instruments | 951 ₽ | ||
| DAC8168IAPW Rochester Electronics | 1 126 ₽ | ||
| DAC8168IAPW Texas Instruments | 1 722 ₽ | ||
| DAC8168IAPW Texas Instruments | 1 765 ₽ | ||
| Pin | 14 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 90 |
| Carrier | TUBE |
| Маркировка | DA8168A |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Code to Code Glitch(Typ) | 0.1 nV-sec |
| DAC Architecture | String |
| DAC Channels | 8 |
| Gain Error(Max) | 0.15 %FSR |
| INL(Max) | 4 +/-LSB |
| Interface | SPI |
| Offset Error(Max) | 0.07 % |
| Output Range Max. | 5.5 mA/V |
| Тип выхода | Buffered Voltage |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
| Power Consumption(Typ) | 2.2 mW |
| Rating | Catalog |
| Reference: Type | Ext,Int |
| Разрешение | 14 Bits |
| Sample / Update Rate | 0.1 MSPS |
| Время установления | 5 µs |
| Special Features | Reset to Mid-Scale |
| Zero Code Error(Typ) | 4 мВ |
- Evaluation Modules & Boards: DAC8168EVM
DAC8168 Evaluation Module
Серия: DAC8168 (4)
- DAC8168IAPW DAC8168IAPWR DAC8168ICPW DAC8168ICPWR
- Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > Precision DACs (=<10MSPS)
