Datasheet Texas Instruments TPA2000D1TPWRG4Q1 — Даташит
СерияTPA2000D1-Q1
МодельTPA2000D1TPWRG4Q1
Автомобильный каталог Моноусилитель звука класса D без фильтров 16-TSSOP от -40 до 105
2-W Filterless Mono Class-D Audio Power Amplifier datasheet
PDF, 831 Кб, Версия: E, Файл опубликован: 31 окт 2008
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка2000D1T
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Analog Supply (V)2.7 Max
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceGPIO
Iq per channel(Typ)4 мА
Iq(Max)6 мА
Iq(Typ)4 мА
Load(Min)4 ohms
Выходная мощность2 W
PSRR77 дБ
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Pin/Package16TSSOP
RatingAutomotive
Shutdown Current (ISD)0.05 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.2 %
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2000D1-Q1 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2000D1TPWRG4Q1
