Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS62200DBVT — Даташит
СерияTPS62200
МодельTPS62200DBVT
Регулируемый понижающий преобразователь, 300 мА, КПД 95 % в SOT-23 5-SOT-23 от -40 до 85
TPS6220x High-Efficiency, SOT23 Step-Down, DC-DC Converter datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 30 июн 2015
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаPHKI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)0.3 A
Iq(Typ)0.015 мА
Package GroupSOT-23
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Synchronous Rectification
Switching Frequency(Max)1500 kHz
Switching Frequency(Min)650 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.5 В
Vout(Max)6 В
Vout(Min)0.7 В
  • Evaluation Modules & Boards: TPS62203EVM-211
    TPS62203 6V Input, 3.3V Output, 0.3A Evaluation Module
  • Evaluation Modules & Boards: TPS62200EVM-211
    TPS62200 6V Input, 1.8V Output, 0.3A Evaluation Module
  • DVS For OMAP1510 Using TPS62200
    PDF, 61 Кб, Файл опубликован: 4 дек 2002
    Portable electronics with long battery lives are unquestionably more marketable. Power consumption of the microprocessor can be reduced by lowering the internal clock frequency and/or even more by lowering the core supply voltage. Dynamic voltage scaling (DVS) is used to reduce core supply voltage to minimize power consumption. This application note explains how to implement DVS using a TPS6220
  • Power Ref Design for TMS320C6472 5Vin DC/DC Converters (1x C6472)
    PDF, 251 Кб, Файл опубликован: 31 мар 2010
    This reference design is intended for designers who wish to design a TMS320C6472 Digital Signal Processor into a system using a nominal input voltage of 5 V, DC/DC converters with integrated FETs, and allowing for ease-of-design and a smaller solution size.
  • Power Solution Using Discrete DC/DC Converters and LDOs (Rev. B)
    PDF, 299 Кб, Версия: B, Файл опубликован: 26 авг 2010
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS62200 (4)
На английском языке: Datasheet Texas Instruments TPS62200DBVT
