Datasheet Texas Instruments TPA005D12DCA — Даташит
СерияTPA005D12
МодельTPA005D12DCA
Стереоусилитель мощности класса D 48-HTSSOP
Datasheet
TSP
Pin48
Package TypeDCA
Industry STD TermHTSSOP
МаркировкаTPA005D12
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
RoHSНе совместим
  • Reducing And Eliminating The Class-D Output Filter
    PDF, 180 Кб, Файл опубликован: 24 авг 1999
    This application report investigates reducing and eliminating the LC output filter traditionally used in class-D audio power amplifier applications. The filter can be completely eliminated if the designer is using a predominatly inductive speaker; however, the supply current and the EMI are higher than if using the full second-order Butterworth low-pass filter. The designer can use half of the com
  • Design Considerations For Class-D Audio Power Amplifiers
    PDF, 144 Кб, Файл опубликован: 23 авг 1999
    This application report provides background information, general equations, and component selection criteria for proper design and implementation of the Texas Instruments class-D audio power amplifiers. Topics include class-D switching and charge pump circuits, signal conditioning of the audio inputs and outputs for both the class-D and class-AB headphone amplifiers, IC Control and indicator circu
Серия: TPA005D12 (1)
  • TPA005D12DCA
  • Semiconductors > Audio > Low-Power Audio Amplifiers ( Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA005D12DCA
