Datasheet Texas Instruments SNJ54AS808BJ — Даташит
Серия | SN54AS808B |
Модель | SNJ54AS808BJ |
Шестнадцатеричный 2 входа и драйверы 20-CDIP от -55 до 125
Hex 2-Input And Drivers datasheet
PDF, 608 Кб, Версия: C, Файл опубликован: 1 янв 1995
![]() 12 предложений от 9 поставщиков Микросхема Логический чип, AND Gate 6Element 2IN Bipolar 20Pin CDIP Tube | |||
SNJ54AS808BJ Texas Instruments | от 1 320 ₽ | ||
SNJ54AS808BJ Texas Instruments | 2 432 ₽ | ||
SNJ54AS808BJ | по запросу | ||
SNJ54AS808BJ Texas Instruments | по запросу |
Pin | 20 | 20 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 5962-8852201RA | SNJ54AS808BJ |
Width (мм) | 6.92 | 6.92 |
Length (мм) | 24.2 | 24.2 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Bits | 6 |
F @ Nom Voltage(Max) | 125 Mhz |
ICC @ Nom Voltage(Max) | 0.013 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | -2/20 мА |
Тип выхода | TTL |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | AS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
tpd @ Nom Voltage(Max) | 6.5 нс |
RoHS | See ti.com |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN54AS808B (6)
- 5962-88522012A 5962-8852201RA 5962-8852201SA SN54AS808BJ SNJ54AS808BFK SNJ54AS808BJ
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
