Datasheet Texas Instruments TMX320VC5410GGW100 — Даташит
СерияTMS320VC5410
МодельTMX320VC5410GGW100
Цифровой сигнальный процессор 176-BGA MICROSTAR от -40 до 100
TMS320VC5410 Fixed-Point DSP datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 30 ноя 2000
Pin176
Package TypeGGW
Industry STD TermBGA MICROSTAR
JEDEC CodeS-PBGA-N
Width (мм)15
Length (мм)15
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1.4
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
    XDS200 USB Debug Probe
  • TMS320VC5410 Bootloader (Rev. B)
    PDF, 239 Кб, Версия: B, Файл опубликован: 30 мар 2002
    This document describes the features and operation of the TMS320VC5410 Bootloader. The contents of the on-chip ROM also are discussed.Important Notice Regarding Bootloader Program Contents:Texas Instruments may periodically update the bootloader code supplied in the ROM to correct known problems, provide additional features, or improve functionality. These changes may be made without
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
На английском языке: Datasheet Texas Instruments TMX320VC5410GGW100
