Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS62050DGSRG4 — Даташит
СерияTPS62050
МодельTPS62050DGSRG4
Регулируемый понижающий преобразователь, 800 мА, напряжение 10 В, КПД 95 % в MSOP-10 10-VSSOP от -40 до 85
TPS6205x 800-mA Synchronous Step-Down Converter datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 26 июн 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаBFM
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)0.8 A
Iq(Typ)0.012 мА
Package GroupVSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Synchronous Rectification
Switching Frequency(Max)1200 kHz
Switching Frequency(Min)600 kHz
ТипConverter
Vin(Max)10 В
Vin(Min)2.7 В
Vout(Max)6 В
Vout(Min)0.7 В
  • Evaluation Modules & Boards: TPS62052EVM-234
    TPS62052 Evaluation Module
  • Evaluation Modules & Boards: TPS62050EVM-234
    TPS62050 Evaluation Module
  • Maximum Output Current of TPS62050
    PDF, 51 Кб, Файл опубликован: 19 мар 2003
    The TPS62050 is a highly integrated synchronous step-down dc/dc converter capable of delivering output up to 800 mA. However, the maximum output current is limited by parameters such as ambient temperature, input-output voltage ratio, and switching frequency. This application report provides the maximum allowable output current of the TPS62050.
  • Adding Hysteresis to Low Battery Input on the TPS6205x (Rev. A)
    PDF, 89 Кб, Версия: A, Файл опубликован: 28 ноя 2007
    The low-battery input (LBI), available on several step-down converters, is often used to shut down the converter when the input voltage falls below a set threshold. This prevents damage to the battery and signals that the battery is at the end of its life and should be charged or replaced. Batteries have internal resistance that causes the voltage to drop as the load increases. This internal resis
  • Optimizing Resistor Dividers at a Comparator (Rev. A)
    PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS62050 (5)
На английском языке: Datasheet Texas Instruments TPS62050DGSRG4
