Datasheet Texas Instruments TPS70202PWPG4 — Даташит
Серия | TPS702 |
Модель | TPS70202PWPG4 |
Стабилизаторы напряжения с двойным выходом, 250 мА/500 мА с низким падением напряжения и встроенным SVS 20-HTSSOP от -40 до 125
Dual-Output, Low-Dropout Voltage Regulators datasheet
PDF, 1.0 Мб, Версия: E, Файл опубликован: 6 дек 2009
Pin | 20 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 70 |
Carrier | TUBE |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | 0.65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Точность | 2 % |
Основные особенности | Enable,Output Discharge,Power Good |
Fixed Output Options | 1.2,1.5,1.8,2.5,3.3 В |
Iout(Max) | 0.5 A |
Iout2 | 0.25 A |
Iq(Typ) | 0.19 мА |
Noise | 65 uVrms |
Output Capacitor Type | Ceramic,Non-Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 20 дБ |
Package Group | HTSSOP |
Package Size: mm2:W x L | 20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG |
Rating | Catalog |
Regulated Outputs | 2 |
Thermal Resistance ОёJA | 32 В°C/W |
Vdo(Typ) | 170 мВ |
Vin(Max) | 6 В |
Vin(Min) | 2.7 В |
Vout(Max) | 5.5 В |
Vout(Min) | 1.2 В |
Vout2(Max) | 5.5 В |
Vout2(Min) | 1.2 В |
- Recommended Power Solutions for the TMS320x2810/1/2 DSPsPDF, 28 Кб, Файл опубликован: 31 янв 2005
This application report provides a table to assist users in selecting the best power solution for their specific TMS320281x application. - Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TPS702 (16)
- Semiconductors > Power Management > Linear Regulator (LDO) > Multi-Channel LDO
