Datasheet Texas Instruments LM3431AQMH/NOPB — Даташит
Серия | LM3431-Q1 |
Модель | LM3431AQMH/NOPB |
3-канальный светодиодный драйвер постоянного тока со встроенным повышающим контроллером 28-HTSSOP от -40 до 125
LM3431/31A/31Q/31AQ 3-Chan Constant Current LED Driver w/Integrated Boost Cntr datasheet
PDF, 1.9 Мб, Версия: G, Файл опубликован: 2 май 2013
Pin | 28 | 28 |
Package Type | PWP | PWP |
Industry STD Term | HTSSOP | HTSSOP |
Package QTY | 48 | 48 |
Carrier | TUBE | TUBE |
Маркировка | LM3431 | AQMH |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 9.7 | 9.7 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Applications | Backlight,Stop/Tail,Turn |
Количество каналов | 3 |
Iout(Max) | 0.6 A |
Iq(Typ) | 4 мА |
LED Current Per Channel | 200 мА |
Package Group | HTSSOP |
Package Size: mm2:W x L | 28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG |
Rating | Automotive |
Special Features | Adjustable Switch Frequency,Enable/Shutdown,Soft Start,Thermal Shutdown |
Switching Frequency(Max) | 1000 kHz |
Switching Frequency(Min) | 200 kHz |
Topology | Boost with Current Sink |
Vin(Max) | 36 В |
Vin(Min) | 4.5 В |
Vout(Max) | 40 В |
Vout(Min) | 5.5 В |
- Evaluation Modules & Boards: LM3431EVAL
Evaluation Board for the 3-Channel Constant Current LED Driver with Integrated Boost Controller
- AN-1656 Design Challenges of Switching LED Drivers (Rev. A)PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3431-Q1 (4)
- LM3431AQMH/NOPB LM3431AQMHX/NOPB LM3431QMH/NOPB LM3431QMHX/NOPB
- Semiconductors > Power Management > LED Driver > Automotive LED Driver
