Datasheet Texas Instruments UC3852D — Даташит
СерияUC3852
МодельUC3852D
Предварительный регулятор высокого коэффициента мощности 8-SOIC от 0 до 70
High Power-Factor Preregulator datasheet
PDF, 400 Кб, Файл опубликован: 5 сен 1999
Package TypeD
Package QTY75
МаркировкаUC3852D
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodTM
Device TypeSingle-phase PFC
Operating Supply Current6 мА
Operating Supply(Max)30 В
Peak Output Sink Current Gate Drive1 A
Peak Output Source Current Gate Drive-1 A
Practical Operating Frequency(Max)0.2 МГц
Special Features< 150W Applications,Transition Mode Control
Startup Current0.4 мА
UVLO Thresholds On/Off16.3/11.5 В
  • U-132 Power Factor Correction Using UC3852 Controlled On-Time Zero Current
    PDF, 323 Кб, Файл опубликован: 5 сен 1999
    The UC3852 provides a low-cost solution to active power-factor correction (PFC) for systems that would otherwise draw high peak current pulses from AC power lines. This circuit implements zero-current switched boost conversion, producing sinusoidal input currents with a minimum of external components, while keeping peak current substantially below that of fully-discontinuous converters. The contro
Серия: UC3852 (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UC3852D
