Datasheet Texas Instruments TPS65986ABZQZR — Даташит
СерияTPS65986
МодельTPS65986ABZQZR
Контроллер USB Type-C™, USB PD и выключатель питания 96-BGA MICROSTAR JUNIOR от -10 до 85
TPS65986 USB Type-C and USB PD Controller and Power Switch datasheet
PDF, 2.7 Мб, Версия: C, Файл опубликован: 31 авг 2016
Pin96
Package TypeZQZ
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeS-PBGA-N
Package QTY2500
Width (мм)6
Length (мм)6
Thickness (мм)0.74
Pitch (мм)0.5
Max Height (мм)1
Alternate ModeYes
ConfigurationN/A
Data RoleDFP,DRD,UFP
Dead Battery SupportYes
External Power Path ControlGPIO
FunctionCC Controller,PD Controller,Passive Signal Switch,Power Switch
Internal Power Path20V 3A Source/Sink,5V 3A Source,5V 600mA VCONN
Iq(Typ)58 uA
Рабочий диапазон температурот -10 до 85 C
Package GroupBGA MICROSTAR JUNIOR
Policy ManagerIntegrated
Power RoleDRP,Sink,Source
Realtime VBUS monitoringYes
USB Speed480 Mbps
  • Evaluation Modules & Boards: USB-CTM-MINIDK-EVM
    USB Type-C™ Minidock Board With Video and Charging Support Evaluation Module
  • Evaluation Modules & Boards: TPS65986EVM
    TPS65986 USB Type-C & USB PD Controller & Power Switch Evaluation Module
  • Evaluation Modules & Boards: TPS65982-EVM
    TPS65982 USB Type-C & USB PD Controller Power Switch & High Speed Multiplexer EVM
  • Evaluation Modules & Boards: TUSB1064RNQEVM
    USB Type-C / VESA DP Alt Mode Re-driving switch Evaluation Module
  • Evaluation Modules & Boards: TUSB564RNQEVM
    USB Type-C / VESA DP Alt Mode Re-driving Switch Evaluation Module
  • Evaluation Modules & Boards: DP-EXPANSION-EVM
    TPS6598x DisplayPort Expansion Evaluation Module
  • TPS6598x PDIO Alternate Mode
    PDF, 531 Кб, Файл опубликован: 13 фев 2017
    The PDIO Alternate Mode allows users to transmit or receive up to four unique digital signals between two systems connected through USB Type-C. The PDIO signals are particularly applicable to applications such as laptop docking stations where push button events can be used to send status information from one device to another like a virtual GPIO. This application report explains the standard impl
  • TPS6598x Configuration Import Guide (Rev. A)
    PDF, 10.3 Мб, Версия: A, Файл опубликован: 6 июл 2016
    This import guide describes how to extract a user's application configurations from an existing TPS6598x device. The extracted application configurations can be reused with later versions of firmware using the TPS6598x Application Customization Tool which enables users to get more features and bug fixes while still retaining their application configuration.
  • TPS6598x User Alternate Modes
    PDF, 6.7 Мб, Файл опубликован: 10 ноя 2016
    User Alternate Modes allow the developer of a USB Type-C Power Delivery system to define custom Alternate Modes to extend the functionality of the connection. This document describes the procedure for configuring a User Alternate Mode using a Texas Instruments TPS6598x USB Type-C/PD Controller and associated software tools. If enabled a custom Vendor ID (VID) will be added to the list of supporte
  • TPS65982 and TPS65986 Quick Start and System Bring Up (Rev. A)
    PDF, 996 Кб, Версия: A, Файл опубликован: 11 ноя 2015
  • TPS6598x GPIO Events
    PDF, 6.0 Мб, Файл опубликован: 17 ноя 2016
    The Texas Instruments TPS6598x family of USB Type-C and USB PD controllers provides a set of GPIO events to achieve desired system behavior. A developer may program custom behavior triggered by GPIO to enable new functionality and even load modified device configurations using GPIO events functionality. These firmware based GPIO events are simple to configure using the provided GUI software tools
  • TPS65982 FW Update from Embedded Controller Over I2C (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 26 апр 2017
  • TPS6598x PD Power Negotiations
    PDF, 3.7 Мб, Файл опубликован: 15 ноя 2016
    This document describes the Power Delivery (PD) contract negotiation in USB Type-C connections per the USB-IF PD specification and its implementation using Texas Instruments TPS65982 USB Type-C and USB PD controller. USB PD is required in USB Type-C systems for power levels above 15 W (5 V at 3 A) up to 100 W (20 V at 5 A) according to the specification. This application report describes the digi
  • TPS6598x OCP Mechanism and Programming Guide
    PDF, 426 Кб, Файл опубликован: 23 окт 2017
    This document describes the functionality of the overcurrent protection (OCP) mechanism of theTPS6598x device and how to program it using the Application Customization Tool. This guide definesTHE peak current and provides steps on how to set the threshold of OCP on the TPS6598x device.
  • TPS6598x DisplayPort Alternate Mode (Rev. A)
    PDF, 7.8 Мб, Версия: A, Файл опубликован: 27 фев 2017
    The DisplayPort Alternate Mode allows transmission of DisplayPort video data over a USB Type-C connection. The mode is negotiated using USB Power Delivery messaging according to the USB PD specification. This application report explains the standard implementation of the DisplayPort alternate mode and how it can be used with Texas Instruments TPS6598x family of USB Type-C and USB PD controllers an
  • Using a TPS6598x-EVM to Emulate Type-C and Power Delivery Products (Rev. A)
    PDF, 3.7 Мб, Версия: A, Файл опубликован: 6 июл 2016
    USB Type-C (USB-C) is emerging as a universal interface that can be used for power data video and audio applications. The TPS6598x product family offers stand-alone USB Type-C and Power Delivery controllers for systems that include a Type-C interface. The product folder on TI.com for each TPS6598x device includes an evaluation module (EVM) that can be used for Type-C testing PD testing and ap
  • TPS6598x Power and Data Role Swaps
    PDF, 6.3 Мб, Файл опубликован: 13 фев 2017
    Power and data role swaps allow individual devices to change their roles under certain conditions. This ability allows a power source to become a sink a data DFP to become a data UFP or both. The roles are negotiated using USB Power Delivery (PD) messaging according to the USB PD specification. This application report explains the standard implementation of data and power role swaps as well as a
  • TPS65982 Designs for Supporting Voltages in USB-PD 'Power Rules'
    PDF, 392 Кб, Файл опубликован: 6 июн 2016
  • PD Alternate Mode: Thunderbolt
    PDF, 3.0 Мб, Файл опубликован: 20 дек 2017
    The Thunderbolt Alternate Mode allows the two sides of a USB Type-C PD connection to discovernegotiate and enter the Intel Thunderbolt 3 mode allowing transfer of high-speed data. The mode isnegotiated using USB Power Delivery messaging as listed in the USB PD specification. This applicationreport explains the standard implementation of the Thunderbolt Alternate Mode and how it can be us
  • USB Power Delivery - Compliance Tests
    PDF, 3.3 Мб, Файл опубликован: 26 апр 2017
    The USB Power-Delivery Certification process requires all PD end-products using Texas Instruments'TPS6598x to comply with the USB-IF's deterministic and communication-engine MOI in addition tovarious other load and signaling tests. This application report explains the setup of three extensively usedUSB-PD testers and configuration of the PD Vendor Information File as per the product's PD fe
Серия: TPS65986 (1)
  • TPS65986ABZQZR
  • Semiconductors > Interface > USB > USB Type-C and Power Delivery
На английском языке: Datasheet Texas Instruments TPS65986ABZQZR
