Datasheet Texas Instruments OPA860IDRG4 — Даташит
СерияOPA860
МодельOPA860IDRG4
Широкополосный операционный усилитель крутизны и буфер 8-SOIC от -40 до 85
Wide-Bandwidth, Operational Transconductance Amplifier (OTA) and Buffer datasheet
PDF, 797 Кб, Версия: C, Файл опубликован: 28 авг 2008
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка860OPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Acl, min spec gain1 V/V
BW @ Acl470 МГц
GBW(Typ)470 МГц
IIB(Max)5000 нА
Iq per channel(Max)11.2 мА
Количество каналов1
Output Current(Typ)15 мА
Slew Rate(Typ)3500 V/us
Vn at Flatband(Typ)2.4 нВ/rtГц
Vos(Max)12 мВ
Vs(Max)13 В
Vs(Min)2 В
  • Evaluation Modules & Boards: DEM-OTA-SO-1A
    Unpopulated PCB Compatible w/Wide Bandwidth Transconductance Op Amps in 8-lead SOIC (D) Pkg
  • Demystifying the Operational Transconductance Amplifier (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 16 апр 2013
    Operational transconductance amplifiers (OTAs) are often among the least understood analog components. However, these devices serve a very useful function that is being implemented on a regular basis in many integrated circuits as an element for more advanced purposes; the current feedback amplifier is among the most prominent example. The purpose of this application report is to show how this bui
Серия: OPA860 (4)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Transconductance Amplifiers
На английском языке: Datasheet Texas Instruments OPA860IDRG4
