Datasheet ТI TPS60250RTER — Даташит
| Серия | TPS60250 |
| Модель | TPS60250RTER |
Высокоэффективный зарядовый насос для 7 светодиодов WLED с интерфейсом I2C 16-WQFN от -40 до 85
High Efficiency Charge Pump for 7 WLEDs with I2C Interface datasheet
PDF, 887 Кб, Версия: C, Файл опубликован: 23 апр 2008
- MSP430 Interface to TPS60250 via I2C Master SoftwarePDF, 499 Кб, Файл опубликован: 1 май 2008
The TPS60250 is a high-efficiency, constant-frequency charge pump dc/dc converter that can drive up to five white LEDs for a main display and up to two white LEDs for a subdisplay with regulated constant current for uniform intensity.A microcontroller (MCU) can be used to control the currents for white LEDs via the TPS60250 charge pump through a standard I2C interface, with the MCU acting as t - Ballast Resistor Calculation – Current Matching in Parallel LEDsPDF, 351 Кб, Файл опубликован: 16 апр 2009
Engineers often need to connect LEDs in parallel. Ideally, the LEDs share current equally. In reality, even LEDs from the same production lot have poorly matched I-V characteristics. This mismatch causes the LEDs to not share the current equally. The engineer can add a ballast resistor in series with each LED to minimize current differences. This application report explains how to size the ball - Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS60250 (2)
- TPS60250RTER TPS60250RTET
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
