Datasheet Texas Instruments LMR24210TL/NOPB — Даташит
СерияLMR24210
МодельLMR24210TL/NOPB
Понижающий стабилизатор напряжения 42 В, 1,0 А для микро-SMD 28-DSBGA от -40 до 125
LMR24210 SIMPLE SWITCHER reg; 42Vin, 1.0A Step-Down Voltage Regulator datasheet
PDF, 1.5 Мб, Версия: G, Файл опубликован: 11 апр 2013
Pin28
Package TypeYPA
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаSJ5B
Thickness (мм).36
Pitch (мм).5
Max Height (мм).675
Control ModeCOT with emulated ripple
Duty Cycle(Max)94 %
Iout(Max)1 A
Iq(Typ)0.7 мА
Package GroupDSBGA
Regulated Outputs1
Special FeaturesEnable,Synchronous Rectification
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)100 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)24 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LMR24210EVAL
    LMR24210 Small Footprint 42V Buck Regulator 1A Evaluation Board
  • Inverting Applications Made SIMPLE With LM4600x and LM4360x (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 20 фев 2015
    Weoftenrequirepowersourceswithnegativeoutputvoltages.Therearemanydifferentwaystoproduceanegativeoutputvoltagefromapositiveinputvoltage.Oneoptionisapolarity-invertingbuck-boostconverter.Theadvantagesofthistopologyarethatitrequireslowcomponentcountandthatitcanbebuiltwithstandardhigh-sideregulato
  • Thermal Design Made Simple With LM43603 and LM46002
    PDF, 535 Кб, Файл опубликован: 15 сен 2014
    This Application Report will walk through the thermal design of power supplies using the LM43603 and LM46002.In the process we will cover common tips and approximations to speed up your design.
  • Cap Drop Offline Supply for E-Meters
    PDF, 291 Кб, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications such assmart grid E-meter applications. The design uses a "capacitive-dropper" front-end combined with aLM46000 SIMPLE SWITCHERВ® buck regulator from Texas Instruments. The circuit provides 3.3 V at aminimum of 50 mA from a line supply of 90 VAC to 265 VAC. Theory of operation as well as designequa
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Absolute Maximum Ratings for Soldering (Rev. D)
    PDF, 52 Кб, Версия: D, Файл опубликован: 9 июн 2016
  • Automotive Line Transient Protection Circuit
    PDF, 346 Кб, Файл опубликован: 1 июл 2014
    Automobileelectricalpowersystemsaresubjectedtomanytortuousconditionsoverthelifeofthevehicle.Inaddtiontoadverseconditionsonthebatterypowerbus,therearealsooperatingextremesduetoenvironmentalfactorssuchastemperature,humidityandlongtermvehiclestorage.Thisapplicationnotewilldiscusshowthesetransientco
  • Compensation Made SIMPLE With LM4360x, LM4600x
    PDF, 457 Кб, Файл опубликован: 29 июл 2014
    Compensating a DC-DC buck converter is challenging if the designer is not familiar with the loop control theory. To achieve a stable design under all corner and adverse conditions, the user must properly compensate the regulator. While DC-DC converters with external compensation provide flexibility, they increase complexity. The LM43600/1/2/3 and LM46000/1/2 are a family of Wide VIN, fully-synchro
Серия: LMR24210 (2)
На английском языке: Datasheet Texas Instruments LMR24210TL/NOPB
